Who sells wastegate actuators? - FirebirdV6.com/CamaroV6.com Message Board
  • Who sells wastegate actuators?
    Mines to damn weak and I need a stronger one....preferably with one with a minamum boost level of 10psi and can go to like 20psi but ill never run that much.
    With the one i have now I cant run more then 10psi and any less then like 5.
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
    what model is your wastegate?
    2001 Pewder Firebird V6 A4 <br />Custom Turbo Kit Details On Site<br /> <a href=\"http://www.cardomain.com/id/njp98\" target=\"_blank\">http://www.cardomain.com/id/njp98</a> <br />Best 1/4 time NA - 15.224 seconds @ 87.55 MPH
      what u mean?
      Past Ride
      Current Ride
        one sec, is it a internal wastegate?
          just get a threaded rod and put hiem joints on the ends too connect it too the swinger and the actuator.
          the get a barrel nut the s about 1.5" long and connect the 2 halves of it.
          there is your adjustment! you can thank all the dsm guys for that one. lol
          boost, you got it???
            thats ok for a few psi but goin from 10-15 that would double or triple spring pressure which will result in a broken wga spring.
            2004 srt4 few goodies<br />13.3 @ 103.4
              not really! i have seen a 10psi gain on a grand national as well as a vw jetta.
              and who cares about spring pressure when it is locked too a certain pressure?
