what crank pully do you use for a custom powerdyne supercharger set up. Will the lt1 crank pully work from the kit the company sells, or do you use something special?
what crank pully do you use?
Everyone running a powerdyne is running the stock balancer since the supercharger runs off the same belt as the accessories. I think a few people with custom prochargers are running a gtp balancer which has a seperate belt for the supercharger.92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
how would you do it with the stock balancer? Would you not run any accessories that way? i would assume you would have to run somthing like the gtp balancer to to have two seperate belt locations for accessories and a seperate one for the supercharger.
Like he said, we use the stock crank pulley. The powerdyne doesn't use the stock tensioner, but rather a fixed tension unit that comes with the kit. You also swap out one idler pulley for a grooved pulley and the supercharger mounts to run off the smooth side of the belt.\'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
http://home.comcast.net/~grayman99/JohnD.htm
take a look. it is one of our many informative sticky posts at the top of this forum.
its real simple, it just adds on as another accessory and runs of the serpentine belt. The mach procharger kit does the same thing but Pathogen used a second belt on her custom kit it believe.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
you wont be dissapointed, its a great car with decent power and gas mileage and is fun as hell to drive. Look for a car with the y87 package (its a performance package that gives you better rear gears, a limited slip diff, dual exhaust, and a better stearing ratio) its a much better starting point. Then do your standard intake and exhaust mods before you move to the serious mods like force induction.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Get an LS1 or Lt1 if possible. I wish I did.2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
