I'm trying to remove the 7 psi pulley and install the 10 psi pulley for my ATI kit but the pulley is stuck on the stud. I obviously removed the bolt and washer but its still don't want to come off. Anybody have any ideas?
Procharger Pulley
Procharger Pulley
1999 Firebird <br />Y87 Performance Package<br /><br />Borla exhaust, 3\" Catco Cat and 3\" pipe throughout, RK Sport Headers, K&N air filter, SLP CAI, Whisper Lid, 36 lb Injectors, ATI 3.8 Intercooled Procharger Kit.Tags: None
Pulley puller. You can get them at any auto store like checker or autozone.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
yep, a two claw pulley puller.
getting the pulley off is the easy part. getting the pulley back on is trickier.
you can try warming up the new pulley in an over to cause it to expand. a little oil on the gear shaft and woodruff key as well to help the new pulley on.
once you get it tapped or pressed in a ways you can use the pulley bolt to 'press' the new pulley on.
if you have to tap the pulley then i suggest wood dowel.
dont let the pulley pullers center point ruin the threads inside the pulley 'shaft.' you can mount the pulley pullers center 'press' to the stock bolt..just keep backing out the bolt a bit to give more and more clearance for the pulley to be pulled of the gear shaft.
Thanks for the help guys.1999 Firebird <br />Y87 Performance Package<br /><br />Borla exhaust, 3\" Catco Cat and 3\" pipe throughout, RK Sport Headers, K&N air filter, SLP CAI, Whisper Lid, 36 lb Injectors, ATI 3.8 Intercooled Procharger Kit.
