i was thinkin....the cast 3.4 manifolds look pretty restrictive and i was wondering if i could bolt up 2000+ tubular manifolds and then get tiagos turbo and bolt that up w/o modifications to the kit. also would i need the 3.8 kit then?
thanks
well since the 3.4 and the 3.8 are totally different blocks and have nothing in common i dont see any way that the 3.8 manifolds would bolt up.
I think he was asking about the newer 3.4L FWD manifolds possibly? These would not work either since the heads are alloy and designed different from the older cast iron heads.
The cast iron heads exhaust ports are spaced like this.
o_o___o
The later Al heads exhaust ports are spaced evenly like this.
o__o__o
Cast iron manifolds are only for those heads.
3.8L exhaust manifolds won't work on a 3.4L
well i guess i'll just stay with my stock manifolds
iwanted to have tubular manifolds w/o modification to the y pipe on the turbo kit...but it doesnt look like that will happen
what do you think would be the difference in HP w/ stock manifolds vs. headers running a cutout in place of the cat... at around 13 psi on 114oct race gas on a stock motor
oh well that solves my problems [img]graemlins/rock.gif[/img] lol
i think i remember reading that now...pacesetters,rksport,or cia
im in high school so not a whole lot of money but i should have it saved up by the end of next year
23 hours ago
