What are the limits of my MAF - FirebirdV6.com/CamaroV6.com Message Board
  • What are the limits of my MAF
    I plan to take the FFF kit past 7 psi. But, what will the maf be sending to the ecu at 12+ psi?
    What exactly will I have to do to my maf and ecu make them recognize the higher air flow so ecu will understand to send more fuel and correct spark timming at boost? I am aware I will need larger injectors, Intense recommened their 42# injectors for use with 12-15+ psi from a t3/t04e hydrid.
    [ July 03, 2004, 04:38 AM: Message edited by: BirdOfPrey01 ]
    will http://www.hptuners.com and a 97 ecu solve all my problems?
      no some are psychological but it will help your car ;)
        im using 57# injectors and i got my PCM tuned buy westers, you would be ok with HP tuners and that will let you dyno tune it in also
        www.turbov6camaro.com
        1997 3800 Series II Camaro
