I've had the powerdyne kit installed for awhile and just had to swap some cracking fuel lines on my FMU. In the process I pulled it apart. Anybody had the experience to estimate what ratio I should be boosting my fuel pressure by from the picture?
I put the fuel system back to stock for a day until I could get the right lines and fittings for the FMU and realized that I don't think my FMU is boosting the fuel pressure much over the stock regulator. Fuel pressure is around 44psi at idle, 50 at 0 boost/vacuum, and as seen just under 60 psi at 7lbs. Until I get on the dyno, I fear that I'm running pretty lean. Surely my FMU is set up higher than 1:1. Any ideas?
http://img204.imageshack.us/img204/5...da060058ag.jpg
http://img133.imageshack.us/img133/7131/xenon0143hp.jpg
