Well I finally decided to go ahead and install my turbo on my car the way it is. I figured before I decide on a compression ratio to make the pistons for and a cam profile I decided it would be good to see how it preforms on my stock setup. I'll just have to run really low boost so as not to distroy anything. Anyway, I'm wondering what size injector to order from Jegs along with some other items of choice. I'm thinking 24# but I'm not sure. What would you guys that have had turbos on this engine reccomend? Is it going to run rough at idle w/ 24#? Should I go lower? Higher? I would like to keep these injectors on the new engine as well that will see boost up to 15#s or so eventually. Anything else I'd need? I'm doing injectors and adjustable fuel pressure regulator for now.
injectors for turbo
injectors for turbo
Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>Tags: None
Injector Math:
#/hr = HP * BSFC / CYLS / DUTY CYCLE
BSFC = Brake Specific Fuel Consumption
I guess if I understand this right, it's how efficient the car is. Most N/A cars are .5.. I think turbocharged cars run .45
Duty Cycle
This is how much you wanna work the injectors. according to several unnamed sources -- its a bad idea to go over 85% or below 75%, so figure .8 on that one. (happy medium)
so by those calculations, if you had an N/A car:
#/hr = HP * .5 / 6 / .8
if you have a Turbo'd car:
#/hr = HP * .45 / 6 / .8
You should check my figures for the BSFC to make sure they are accurate, but other than that -- that should all be right.
-R
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club - WCFB Message Board
Does raising the pressure w/ an afpr change these equations? If you raised the pressure could you get away with a smaller injector?Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
changing the fuel pressure would more than likely change either your: duty cycle or BSFC
not sure cause i havent played with one. anyone out there know the answer to this? maybe this should be asked in the advanced technical forum as well since its a little beyond general tech info.
-R
can't raise FP and go to a smaller injector or you will go too high on the duty cycle, gotta stay around 85%
Id go with stock LT1 injectors for now, they are easy and cheap to get, and 24lb/hr should be enough for now.
[img]graemlins/burnout.gif[/img]
Where can you find LT1 injectors? Are you talking about used ones? Ebay doesn't have a good selection right now. Can't mustang 5.0 injectors be used as well?Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
<blockquote>quote:</font><hr>Originally posted by TurboProject:
Where can you find LT1 injectors? Are you talking about used ones? Ebay doesn't have a good selection right now. Can't mustang 5.0 injectors be used as well?<hr></blockquote>
I have 38 lb injectors if you are interested. They are redtops!!THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
How much?Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
You're gonna be stinking rich at idle and lean on top unless you control it.1995 Custom turbocharged 3.4L Camaro<br />- Custom Garrett T3 turbo, .48/.63 A/R<br />- 30lb/hr bosch style injectors<br />- Aeromotive AFPR<br />- MSD 43 gph Inline Fuel Pump<br />- Custom Controlled ECM<br />- Just the beginning........<br />-<b>And the end:(</b> Turbo is gone.
I will let 'em go for $150.00 and I assume you have a way to control them? Yes as v6turbo has stated depending on what your FPR is...you will definately need to control 'em at the bottom, they won't lean out at the top-end though...@ idle and low RPMs is what you want to watch...THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
<blockquote>quote:</font><hr>Originally posted by 94-3.4:
How exactly do you control the injectors? If i were just to slap in some lt1 injectors would the car run good or is it going to be bad. Just a little confused.<hr></blockquote>
Simple. 19 resistors, 4 relays, one throttle switch, 4-8 position dip switches, and a whole lotta wire.1995 Custom turbocharged 3.4L Camaro<br />- Custom Garrett T3 turbo, .48/.63 A/R<br />- 30lb/hr bosch style injectors<br />- Aeromotive AFPR<br />- MSD 43 gph Inline Fuel Pump<br />- Custom Controlled ECM<br />- Just the beginning........<br />-<b>And the end:(</b> Turbo is gone.
<blockquote>quote:</font><hr>Originally posted by V6Turbo:
Simple. 19 resistors, 4 relays, one throttle switch, 4-8 position dip switches, and a whole lotta wire.<hr></blockquote>
Sounds like a party to me! :DHot Cammed LT1 Sleeper
Can to perhaps elaborate? Maybe how all these things connect? :DWayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
