I have my 3.4 plenum modified with an lt1 throttle body. I have the regular rubber boot to mount on it but I don't think it would be good to use this in my turbocharged application. Where can I get a rubber(or some material) adapter to go from the elliptical throttle body to the round tube coming from the turbo? What do the lt1 supercharged guys do? Is it possible to make one?
lt1 throttle body hook up
Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>Tags: None
<blockquote>quote:</font><hr>Originally posted by 97RallySport:
so will a lt1 throttle body work on the 3.8?<hr></blockquote>
No, and there is no reason to. See the discussion in the Technical Database regarding TB sizing.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Do they sell those parts individually?Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
I am not sure how it would hold up onder boost, but before you spend $100. Home depot in the PVC piping department, has 3in - 3in rubber couplings, and other sizes. They are close to half in. thick rubber, and setup to use normal automotive clamps.
It show I made my home made CAI, I jsut used the stock clamp, on the throttle body since it was oval shapped, I clamped the hell out off them and I cannot pull them off either throttle body or piping by hand without lossening them. It cost about $4. might be worth a try if the only other alternative is $100.
I think it looks similar to what people use on super chargers, jsut this stuff is a little thicker.
The whole thing is about 5 in. long, 3in. diameter. I think it is used exactly for underground drainage.
http://www.roadraceengineering.com/hoseandclamps.htm
Silicone Reinforced Transition Hose
should work, the 2-3in one should work, [img]smile.gif[/img]
<blockquote>quote:</font><hr>Originally posted by v6maro:
I wouldn't trust that stuff, lets just put some $4 crap on here and have it sucked into the engine, yeah, thats good.
-Steve<hr></blockquote>
actually I would think it ot be pretty storng, worst that would happen, is it would blow intake pipe off, or jsut fall off the throttle body.
Jsut my $0.02 I always go the cheap route, if I wanted to spend $25k on my car I owuld have gotten a z28. [img]smile.gif[/img]
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
