Does the P600 B reqiure tapping into the oil pan? - FirebirdV6.com/CamaroV6.com Message Board
  • Does the P600 B reqiure tapping into the oil pan?
    Im not sure if this makes sense, but if I can remember correctly some superchargers require tapping into the oilpan, is this true for the P600B? I cant remember if it does or doesnt, I have a bad memory.
    thank you
    1998 Artic White M-5<br />K&N filter, whisper lid, undercar ramair, Dis-4, MSD 8.5mm SC, bosch plat 4+, BMR STB, Jet stage 2, Poly tranny mount, B&M Ripper, 1le DS, 1le Pan hard rod and lca\'s, LSD, hi-flo cat, flowmater, Kumho 255/50/16, and centerforce dual friction clutch.<br />(E.T. ?, but I beat a 15 sec flat integra by 3 cars in 3rd gear and pulling)<p> <a href=\"http://www.geocities.com/fbodies9870\" target=\"_blank\">http://www.geocities.com/fbodies9870</a><p>*****CAR TOTALED*****<p>2002 Artic White z28 A4 Loaded
    Yep.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      it's not that big of a job, just messy, make sure one is in front, and one is behind the screen
      -Steve
