I want to do the blower bolt-on, and not take on the exhaust mods. At least not anything cat-forward. I might go cat-back, later. But I figure the boost will be 90% of the gain, with only another 10% or so, playing with the exhaust. I'm all for getting the 90% easy, and letting the 10% slide... The only concern with this approach, being the stories here about blowing dipsticks, seals, etc.
The two approaches I've seen here to deal with that problem have been:
1. Eliminate exhaust restrictions.
2. Improve the PCV side of the equation.
The pcv mod would be my first preference.
So, I have what may be a dumb question, but maybe not... Seems that the pc valve itself will be the weak link in keeping boost from entering the crankcase directly. Have you guys moved the intake end of the pcv upstream of the blower, or have you left it downstream? Upstream it should always see vacuum, where downstream it's going to get hammered when the boost comes on. Plus the pcv will still be able to be active under boost conditions, helping to additionally relieve any pressure that may slip into the crankcase from the cylinders.
p.s. I love this idea of putting a blower on a stock sleeper v6!!! I hope you guys get the brackets and stuff worked out.
