Hi all,
I've been reading the posts in this forum for a short time now. However, I've been doing research for months about performance upgrades and bolt ons for the 3.4L. I've actually got a miata that I recently started installing a 3.4L into. The engine will have a set of jet hot coated hooker headers (originally for a jeep with the 2.8L v6), cam-lifters and underdrive pulleys. I wanted to go with two t-3's or two hybrid t3/t04's. However, now that i have purchased a nice set of headers, it's almost a shame to have to ditch them for custom (very exensive) ones later. I will also have a cone type filter right over the throttle body and true duals (3") into 2-way cats and two dynomax mufflers.
I am using a stock t-5 out of a camaro with the exception of an 88' s-10 bell housing (for the slave cylinder and so that it places the tranny vertical instead of offset in the usual camaro). I am also using an s-10 (internally balanced) flywheel and clutch pack, for now to cut costs. The rear end is still the stock miata unit that has 4.10:1 gears.
What type of hp do you guys think this setup will make (at least 200hp at the fly, I hope?). And what will I run in the 1/4 mile?
Check out the web page guys, let me know what you think...
http://34v6miata.tripod.com
Thanks a lot for any feedback guys.
kerist abedi
kerist abedi
