if i were to install gtp pistons and leave the rest of the motor alone could i run 10psi of boost for everyday driving. of course i would need to up the fuel system and things like that..but could this work, i know our motor is strong but the weak link is our pistons
boost with gtp pistons?
I think this is another 3.4/3.8 mixup. The 3.4 guys have forged rods.. we don't.. they have forged rods because their motor is auctually a stroked 2.8liter..-Brad
2000 V-Star Custom 1100
:rock:
you can order the crank, rods, pistons, bearings, and rings all through GM Parts direct. Check stefan's site under umm I believe the link is "engine" and he has pretty much all the info you will need..-Brad
:rock:
Going from 9.5:1 to 8.0:1 compression will require you to run significantly more boost to compensate for the compression loss...
If you plan on doing this, plan on running way more than 10psi of boost to make it worth swapping pistons...2002 5-spd NBM Camaro
Details: www.1lev6.com
So then how much boost would u say we should run with the GTP pitons Card? Just asking what u think is safe not try to be a smart a$$ or anything ThanksSilver 2000 Firebird A4<br />3.8 A4<br />14.746 @91.98 Feb /03/02<p>1990 Mitsu GSX 5Spd I just got it.<p>Otis for President 04 !!!!!!
I think GTP pistons are 8.5:1 compression Cardinal. Just what I remember reading [img]smile.gif[/img]
As for boost, well, it depends.
Lets say you wanted to run ridiculous boost. First off, you would want low compression 3 ring pistons (you get more HP from boost than compression). Then, you would want to make youre motor flow as much air as possible (that would in turn lower boost in the block, but you would probably see an increase in power, because the charger is still flowing the same amount, or more, air). Finally, you would want to cool the air.
Grand National guys run 25+ lbs of boost on 8:1 pistons, forged everything, air to air intercoolers, and alcohol injection (to cool everything further). I think that is possible assuming you don't get blow-by (so much pressure that the air gets past the piston & into the crankcase).
It all depends on what you are willing to do.
You also gotta remember that if you are getting knock on stock internals, switching over to GTP isn't going to do you a damn bit of good.
Personally, I think 15 lbs is reasonable w/ a good intercooler.2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
12lbs @ 9.5:1 is the same as 15lbs @ 8.5:1 as far as horsepower goes...
Basically you need +3psi of pressure to compensate for the new lack of compression...
The only way GTP pistons are going to help you is if you can run more than a 3psi difference on them over the stock ones.
i.e. the stock pistons can only handle 11psi, but the GTP pistons handle 17psi... That would be a gain in your favor [img]smile.gif[/img] . But if you find the stockers handle 11psi, and the GTP ones handle 14psi, and going past either limit causes engine damage/knocking/etc... Then the pistons aren't what is limiting you!
[ March 10, 2002: Message edited by: TheCardinal ]</p>2002 5-spd NBM Camaro
