lets here what you think is the best combo for a turbo cam....i wanna be able to use LS1 valvesprings....so what specs would you recomend with the GTP block, and PnP heads? Ive got some ideas I just wanna see what you guys think.
Opinions on a good turbo cam.
Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015Tags: None
1/5 1.0 lobe sep lol00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
turbo cams are completely backwards from a NA or blower cam, the exhaust duration is normally quite a bit smaller than the intake, i cant give you exact specs but i know that much, sorry...<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
what specs are they? i dont want nothing huge....just a nice cam that i can use with LS1 valvesprings.
[ January 24, 2004: Message edited by: Shane ]</p>Past Ride
Current Ride
You can use a split duration cam with intake with higher duration or you can have intake/exhaust at the same duration. I think the specs above would work really nice. I dont think you should go with a huge cam just for tuning reasons and bad tuning with a turbo would be hard to fix. Keep it small.
How much boost do you plan on running?
[ January 27, 2004: Message edited by: pgriffith ]</p>
Check out the Intense stage 3 Turbo cam.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
stage 3 cam is WAY too big......im planning to run 15-18psi or w/e it takes to runs mid 11's with the heads/cam/GTP block.Past Ride
Current Ride
www.turbov6camaro.com
1997 3800 Series II Camaro
u have a turbo 3.8?Past Ride
Current Ride
<blockquote>quote:</font><hr>Originally posted by mattsv6:
116lsa is huge. looks like a good cam but it is on the big side. i hope all is well with the computer and you dont wind up having too wait for the ecu too catch itself like mine does.lol<hr></blockquote>
i sked about that, they said it will give me a SES light if it idles for a while, lol thats why i got auto tap.
what does you comp do? is it just to slow? or what?www.turbov6camaro.com
<blockquote>quote:</font><hr>Originally posted by Shane:
u have a turbo 3.8?<hr></blockquote>
i will if i ever get out of Iraq, right now motor about to get taken out and taken to shop to get bored and all the goodies put in [img]smile.gif[/img]www.turbov6camaro.com
