Ive had it in for roughly 2 weeks and my general impression of it is very good at this point.
Upon first installment I could get no more than 4 pounds of boost with an inch-inch and a half of play in my belt.
I then tightened the belt to one inch of play and got 7 pounds of boost. This felt good but I wanted more. I was going to tighten the belt down to the recommended half inch play when I realized that the current belt of 104.5 inches was too lond and could not be tightened anymore without damaging my idler pully. I went and bought a 103 inch Dayco belt and put it on. The results were amazing!!!!
I got 10 psi in first gear and 10 psi in second gear. 3rd gear will drop to 4-5 and build to 51/2 before I hit the speed sensor at 95 mph and 4800 rpm.
I have tried to dyno in third gear but because of my speed sensor I can not build boost in 3rd gear like I can in first and second gear.
The results were 207 rwhp with 4-5 pounds of non intercooled boost at 4800 rpm's and 95 mph. The temp outside was 88 degrees.
I was disapointed that I couldnt get a real third gear dyno because of my speed sensor kicking in so low. It is very important that my car gets to the 6000rpm redline because my boost is rpm dependent. If I could get my car to the 6000 rpm redline my boost in third gear would be between 7-10 psi and would significantly affect my dyno numbers. There is currently a new pcm plan in the works.
I then decided to do my final run in second gear. The personell at the shop insisted that I didnt do this . They said that I would dyno much lower and be wasting my last pull. Normaly on an NA car this would be true. But when you can build 7-10 pounds in second gear vrs 4-5 pounds in third gear then there may be a different outcome.
The results were 217 rwhp with 7-8 pounds of boost at 60 mph and 5600 rpm's. I was not very happy with these numbers at the time but now realize that 217 in second gear is not bad and theres plenty of room to grow in third gear.
The 10 pound pully held for 1 day and then slipped down to 8 pounds. All new belts stretch out at first. I tightened it down to the recommended half inch of play and then the 10 pounds returned.
2 days later this slipped down to 8 pounds again. I sprayed on some Napa auto dressing and the 10 pounds returned again. This time it lasted for 3 days before slipping down to 7 psi.
I was gonna tighten the belt for the final time (usualy by the 3rd time you tighten a new belt it's done all the stretching it gonna do) But I felt happy with the 7 pounds that comes on so much more instantly than my old 3.1(6 pound ) pully and left it alone. The 7 pounds has has lasted for the last week with no hint of slip. It will ocassionaly even catch and give me 8 pounds.
The reason I dont tighten it one last time to always have 10 pounds of goodness is because Im scared that 10 pounds f nonintercooled boost may be putting my car on borrowed time. Once I get a BLOW OFF VALVE and the SMC I will tighten her down for the final time. Until then Im very happy with the 7-8 psi and I highly recommend that eveyone with a powerdyne spend the 125$ for a 2.70-2.90 pully from ASP racing and then do the JOHNDPOWERRAP.
Words cannot descibe the feeling of knowing your powerdyne is slipping and still getting 7 pounds of IMMEDIATE BOOST. especialy when comparing it to the old 3.1 pully that would slip down to 4 measily pounds or build up to 6-7 pounds when the belt was super tight and only last for a day.
Well Thats all I know so far. I will be ordering a new pcm soon and then will go back and see what my car can really dyno in third gear with 7-10 pounds of boost.
[ February 01, 2004: Message edited by: 98GREENGLOW ]</p>
