What contacts a rubber belt the best. Yep you guessed it rubber so how hard would it be to get the pully rubber coated.
One thought on makeing a powerdyne pully stick
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
Belt dressing seems to help me. I just use the stuff from napa. It makes the belt sticky and seems to build up boost faster. I have seen 9lbs many times using belt dressing. It does wear off pretty quick but would be enough to get a few track runs in and then squirt some more on.1997 Supercharged Firebird<br />14.01@99.7mph 2.1 60ft.
A double sided ribed belt alone wont solve the problem. You are going to have a ribed belt running on a smooth pulley, you are going to have to change the supercharger pulley to a groved pulley. Also i think the water pump pully is smooth and i thought one more pulley is run off the smooth side, this means those would have to be switched to groved pulleys as well. You can get a groved supercharger pulley from powerdyne but i guess you would have to take the other pulleys into a machine shop and have them make you a custom groved pulley.1997 Supercharged Firebird<br />14.01@99.7mph 2.1 60ft.
I am just not gonna run the belt down to the AC that will make the belt wrap around the supercharger pully.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
