Paging Magnus - FirebirdV6.com/CamaroV6.com Message Board
Paging Magnus
  • Paging Magnus
    Hey, if magnus or anyone else would help it would be great. As most of you know I turboed my car, and I had the engine replaced recently also, and my car is gonna be out hopefully this week. I do not want a repeat of what happened. What should I set my MSD DIS4 to when it comes to the ignition retard settings? The lowest it can start is at 4000RPM, and there are alot of degrees of retard I can set. I am going to run between 6 and 8 PSI, and I am running with an FMU. If I am missing any peices of my puzzle let me know, I plan on getting the boost timing master controls soon, but for now I want to run safe enough till I buy it. Please give me some input.
    By the way Magnus, I emailed that guy you told me to about the reprogramming, but he never got back to me, is there a better way to reach him, or is there anyone else that can reprogram my ECU?
    [ November 11, 2002: Message edited by: Formulao96 ]</p>
    New Car--- 2000 Trans Am M6--SLP Lid, K7N Filter, 160 degree Thermostat, Loudmouth Exhaust, Smooth bellows, MAF ends, ASP Pulley, 4.10 gears, Y2K Chrome Vette Wheels, 2\" drop.. More to Come<p>Dyno <br />325 RWHP <br />325 RWTQ<p>Cardomain Site <a href=\"http://www.cardomain.com/id/formulao96\" target=\"_blank\">www.cardomain.com/id/formulao96</a>
    i emailed www.zzperformance.com and he said he can custom my pcm for $450 Also what kind fo fuel delivey do u have. IF u are not getting enghough fuel then that will cause KR whice is bad of course maybe some 28 lbs injectors and a bigger intank fuel pump to make sure u are suppling enghough fuel. Why not use one of those craning timing retard units made for superchargers and turbochargers it retards the timing more and more the more boost u build
      Hey Formulao96 i seen in a thread somewhere that you have some parts from a 3000gt vr4. My roommate is doing a tt conversion on his n/a 3000 and has everything he needs except a few oil lines for the turbos. would you happen to have any of those that you would sell?
      <a href=\"http://www.redlinevsix.com/\" target=\"_blank\">RedLineVSix</a><br />98 NbM Camaro M5
        All I have is the intercoolers.
        [ November 12, 2002: Message edited by: Formulao96 ]</p>
          oh ok... thanks anyway
            <blockquote>quote:</font><hr>Originally posted by Formulao96:
            Well... this really depends. GTP guys with 8.5:1 compression are able to push 15'ish lbs of boost with 27+ degrees of timing depending on octain.
            So it depends on what octain you run and intake charge temps.
            Monitor with a scan tool and see if you get knock retard. If you do make sure your fuel delivery is there, you fuel pump is adequate as are your injectors.. air/fuel ratio is acceptable.. and then up the octain if its low.. If you CONTINUE to get knock retard, then start pulling timing with the DIS-4.
            If you're having a hard time pushing even 20 degrees of advance then I'd start to look at fuel delivery.. and try colder plugs.
            Hmm.. I'd e-mail him again.. He's been pretty busy lately.. I hope they can help you out. They are the only guys I know who have the capabilities to do in-depth tuning.
            <hr></blockquote>
            Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
              Are you talking about dave buckshaw magnus?
              Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                Yup!
                  <blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
                  Are you talking about dave buckshaw magnus?<hr></blockquote>
                  I could do it for you for free.
