how much boost will a stock 3.4 take
how much boost
how much boost
94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>Tags: None
I know that stock 3.8's can safely take up to 9lbs with the FMU. I think it all depends on your injector size. I'm not too sure about a 3.4 though. The kit usually has a 6lb. pully, I'm pretty sure that would be ok. If your talking sc. I don't have a clue on the turbo's.Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
tiago has run 14psi on race gas on his stock internal 3.4 with no problems1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
Originally posted by Teufel Hunden:
The answer is nobody knows. No one has broken an L36 or an L32 due to power production alone.
[ June 28, 2005, 01:07 PM: Message edited by: Linxs ]Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
Originally posted by Linxs:
</font><blockquote>quote:</font><hr />Originally posted by Teufel Hunden:
The answer is nobody knows. No one has broken an L36 or an L32 due to power production alone.www.turbov6camaro.com
1997 3800 Series II Camaro
Because of the stupid MAF! I bet I would have blown mine by now if it was not for that... [img]smile.gif[/img]1998 Camaro, Arctic White<br /><br />Garrett P-Trim T04 turbo<br /><br /><i>348rwhp, 379.5rwtq @ 10psi</i>
Originally posted by '94firebirdv6:
</font><blockquote>quote:</font><hr />Originally posted by jessica2112:
tiago has run 14psi on race gas on his stock internal 3.4 with no problems </font>[/QUOTE]14psi damn i was thinking 8-9 the most how is the CR on tiago car i was looking for like 7 the most on my car stock internals.... what did tiago run with 14psi(ET)94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>
I run 10psi everyday on my compleatly internally stock daily driver 3.4 with 219,800 miles. I've never even had the valve covers or lower intake off. I've been running it this way for at least a year.
A couple of times the boost controller wasn't working right and it shot up to 15+, but that was only as long as my reaction time to let off the throttle. So no harm done.Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
hey turboproject i was looking at your page and saw u had megasquirt would you recomed it and did you buid it on your own94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>
I would highly recommend it. I did build it myself too. As long as you read up on a lot of what they have out there for it(such as the megamanual: http://www.msefi.com/msinfo/manual/mtabcon.htm ) you should be able to work through it. It's really awesome to be able to adjust fuel and spark. I also have a LC-1 innvovative wideband sensor so now I can tell exactly what A/F ratio I'm running and can adjust for it at whatever running condition I want. The megasquirt will also do A/F ratio targeting where you can set it to follow certain ratios at whatever condition, baised on RPM and MAP/boost.
I'm running a V2.2 board with the MS-I processor and some custom code that has been developed for it that gives you things like cooling fan control, knock sensing retard, boost control, etc. It's called megasquirt-n-spark-extra: http://megasquirt.sourceforge.net/extra/index.htmlWayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
And the best part is that it's super cheap! You can get a ready to assemble kit for $140 from here: www.glensgarage.com
This is for fuel only and you just have to wire it into your exsisting sensors, injectors, etc. I ran like that for a while and had the stock computer control timing. Then I spent a little more($60-$80, mostly on junkyard parts) and set it up to control ignition as well. It uses a ford EDIS system w/ a crank trigger. But there is work being done to make it control the GM DIS system on our cars.Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
so you are no longer running the stock pcm how about wiring all that stuff.... any track time on your setup thanks for the info94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>
and where did you get that intake with lt1 TB and how much94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>
