how long will a 3.8 with forged internals last with a turbo with average boost. raced every once in a while and when a honda talks crap.
how long will it last
96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>Tags: None
how long a motor lasts with or without a turbo depends on so many things that it is hard to give you an accurate answer.
if you keep up on maintenance and only put h car on boost from time to time it will last nearly as long as a stock motor.
forged internals do benefit from being allowed to run for a moment before load is ptu on them, but that is about the only difference you would see from day to day.
later
timNJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
A engine with low boost will last just as long as any other engine if done right. Of course, stock engines can go out in 5k miles to 200k miles, so that doesn't tell you much.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
