Turned the boost up............ - FirebirdV6.com/CamaroV6.com Message Board
  • Turned the boost up............
    Finaly found a bolt that fits the cap of my wastegate.
    Turned it 2 turns.... Hmm.... barely moved at all, better give it 5.
    Turned the WOT timing down to 10* just to be safe.
    Rolling onto the freeway 45mph 2nd gear. I eased into it, boost gauge shot to 17psi of boost, at which point both tires broke lose. Never even hit full throttle. The feeling of that torque is beyond words.
    After changing my pants, I looked at the log file. NO knock [img]graemlins/rock.gif[/img] , but another half second longer, and the maf would have maxed. Good thing the tires let go.
    Time for more boost....
    Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
    :eek:
    97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
      I bet thats a wild ride. I like the feeling of 8psi
      \'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
        that is awesome!!!!!
        be carefull tho
        17psi is ALOT especially for a stock fuel system
        1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
          Streched out the MAF signal with MAFT, but I'm running out of fuel at around 4900 and 15psi.
          I'll have to switch back to gasoline, or get bigger injectors I guess.
          Turned the boost down to 11psi for now, car feels like a dog, after 17.
            Dang, you got to take that thing to the Track and get it dynoed.
              dyno first then track
              www.turbov6camaro.com
              1997 3800 Series II Camaro
                Yes, you're right dyno and then track.
                There's a V6 Stang with a stock motor that turned it's wick up to 17 psi and did 10.98 et on the track. Ofcourse that was with two small turboes. I wonder how a big one would do.
                  :eek: [img]graemlins/rock.gif[/img]
                  2004 CE Corvette 10.86@132mph
                  2011 Cadillac CTS-V
                  2006 Mitsubishi Eclipse GS
                    well unfortunatly, the F-bodys are having trouble with the MAF. Look at my sig. 330 @ 7PSI. I average 22 HP per PSI. you can do the math fron there. Before I put 315's in the rear I would break the tire loose at the top of second gear (245 tires). It's a great feeling! I'm gald others are experiencing it now [img]smile.gif[/img]
                    Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
                      MAFT works great as far as I can tell. Its accurate to about 38lb/min, and the recurved table goes to 55lb/min so I think I should be good there.
                      What did you end up doing Linx?
                      I'm curious about one thing, according to injector duty cycle tables, I'm at 106.3% duty cycle at 4000RPM and 17psi. How is this possible?
                        your pcm is just holding the injectors open trying to supply fuel after 4000 RPM your VE falls off and you dont need as much fuel
                        Linx is going to mega squirt. :eek:
