Is this the turbo that comes with the kit:
Garrett T3/T04E (60/.82) (#466159-5008S)
T3/T04E - Non Ball Bearing Center Section, .82 A/R T3 Turbine Housing, 76 Trim Turbine (Stage III), .60 A/R T04E Compressor Housing, 60 Trim Compressor Wheel. 4 Bolt Discharge Flange
Shane
Just received the turbo today. While I am excited to get it I am a little confused. The housing says "Garrett A/R .50" and "3029" on the exhaust housing. No other part numbers or casting numbers.
Is this a mistake? Was I shipped the wrong one by accident?
Shane
Perry V.<br />\'97 Chameleon Bird w/ too many toys to list.<br /><a href=\"http://www.geocities.com/umvagia0\" target=\"_blank\">http://www.goecities.com/umvagia0</a>
Just to let ya'll know, I'm going down to Houston to get my T66 and upgraded IC installed from Tiago this weekend! I will then be hitting up our local 1/4th track about 2 or 3 weeks later! [img]graemlins/rock.gif[/img] [img]graemlins/rock.gif[/img] LETS GET SOME NUMBERS OUTTA THESE BOYS!
Shane, ya it's part of tiago's kit. Don't really see any model or serial #'s on it though.....ah well as long as it sticks me in the low 13's or high 12's...then i'll be a happy camper [img]smile.gif[/img]
right behind the 4 bolt flange mine says 3029, but thats really the only other numbers on it. Im sure it will work fine but thats not what was advertised, and thats not what I paid for.
Shane
The turbo described above is not what was sent with the kit. The compressor cover is a .50 A/R and uses a .82 Lotus T3 turbine wheel that was machined to work with our kit. It is internally gated and uses a v-band discharge.
It is the same turbocharger that was used on Radcat's car. It's the same turbo we just made over 400 ft/lbs of torque. The only changes between the prototype system and the production system was y-pipe on the y-pipe and Radcat was running a set of production pipes for that dyno session.
It was my mistake I thought they were 0.62s and thats what I told a few of you. I had not seen radcat's car in over a year but we its confirmed it is the same turbo we used on his and the performance will be the same. Email me if you feel you got the short end of the stick.
<--- In shock over this lol
[img]graemlins/twak.gif[/img] me [img]graemlins/slap.gif[/img] me
