Assuming that's the stock turbo, and I believe it is, you would have no trouble spooling up quickly to any boost the turbo is capable of pushing, considering it was used on an 1.8L (2.0L?) car. It would also almost certainly run out of juice after 3500 rpm or so- that's just my prediction from the research I've done.
Now if we're not talking about the same turbo, that's a different story.
Sam
AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
How much airflow can that turbo generate though. You can generate all the boost in the world, but if you don't have the airflow to back it up you're not gonna have any power.
No it will definately produce power, it's a good turbo, capable of up to 17PSI, just definately will poof out before the end of your RPM range.
I believe it's the same turbos I have sitting here that I will be using for my twins setup, stock off 1G and 2G Turbo DSM's.. also named the Garrett T25.
If single I would DEFINATELY opt for the biggest T3- .63 A/R or one of the smaller T3/T4 hybrids.
[ December 04, 2002: Message edited by: xjarayax ]</p>
Are the eclipses 2.0L or 1.8L? Typically for things like this... you want to see what turbo cars with an engine displacement of about 1/2 of yours uses, if you plan on using a twin setup.
