does any one here knows were can i find a doubled side ribbed belt thanks
ribbed belt
Not sure where to find one but I would also like to know. Aren't you running a powerdyne supercharger? I think your belt size is the same as a 95 mustang cobra. Someone on here posted that a while back. More then just the supercharger run off the smooth side of the belt though. I don't think you can run a ribbed belt on a smooth pulley becuase there would be less contact area between a ribbed belt and a smooth pulley. I am interested in doing something like this to get more grip out of my powerdyne supercharger but I think it would mean changing the supercharger pulley, water pump, and whatever else is run off the smooth side of the belt to a ribbed pulley....1997 Supercharged Firebird<br />14.01@99.7mph 2.1 60ft.
you will have to change the tensioner pulley the water pump pulley and the supercharger pulley but that is just small stuff compared to the gain youll see i spoke with gates and they are working on building some belts with grip on both sides but they are not sure wen it would be released i was hoping some one knew if there is any other company that makes them
