Could I run the powerdyne 6psi kit without a FMU?
Is the Fmu really nessicary
Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.Tags: None
hrmmm fmu= fuel managment unit
hrmmmm is running lean with forced induction a good thing
NO
DONT DO IT
why do people gotta try a cheap way
but no really dude you need one you would run lean with out it im sure and then there would go your motor and that would cost you more then a fmu
Finaly got some attention. Are Fmu's universal?Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
Time for my ignorance to show - What exactly does a Fuel Management Unit (FMU) in relation to the whole forced induction deal? I was under the impression that the onboard computer would take care of supplying enough fuel for the extra O2 in the cylinders.
Also, can anyone tell me what MAF+ is I know Mass Air Flow (such as in the sensor) but whats with the +?
Okay, my dumb questions are over now, I think I know everything else! :DNot a problem, just a challenge...
Increased fuel pressure as your boost rises.
Ideal for turbos with rising rate PSI.
SamAIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
Is the fmu the same as a rising-rate fuel regulator (boost input raises pressure mechanically), or is an fmu something that is electronic? Thanks.
Joe
[ December 12, 2002: Message edited by: Riles ]</p>All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
<blockquote>quote:</font><hr>Originally posted by Pike:
Also, can anyone tell me what MAF+ is I know Mass Air Flow (such as in the sensor) but whats with the +?<hr></blockquote>
You may be thinking of the MAFT+.
MAFT is a MAF Translator, altering the air flow signal that is being reported to the pcm, in order to richen or lean the a/f ratio.
The MAFT+ also includes an ignition timing modifier in the box along with the maf translator.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
<blockquote>quote:</font><hr>Originally posted by Riles:
Joe
[ December 12, 2002: Message edited by: Riles ]<hr></blockquote>
yes its a rising rate regulator pretty much, boost controls it.
<blockquote>quote:</font><hr>Originally posted by phoenix64:
Could I run the powerdyne 6psi kit without a FMU?<hr></blockquote>
YES you can. I run my 6lb kit with no FMU. I bought my kit used and the FMU was bad. It was boosting my fuel pressure up over 100psi and locking up the injectors. So I pulled the FMU off and it runs perfectly now.
You MUST run the external fuel pump to do this tho. The fuel pump will provide the extra fuel and the computer will adjust as needed. I would also suggest going with a bigger injector.
With no FMU I'm actually running a tad rich, even with the MAFT+ leaned out 10% on the base.
I would not suggest trying to run with no FMU unless you have a way to monitor your O2 readings to make sure you aren't running lean.
IMHO, FMU units lead to blower motor failures. I've heard way too many "my FMU died and KaBoom" stories.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
