engine problem.. - FirebirdV6.com/CamaroV6.com Message Board
engine problem..
  • engine problem..
    some day ago... i got my Tuning ECU from matt~
    so as he told.. i took off MAFT and FMU and
    TRC-1.... and.. i started my engine..but..
    my engine's idleling couldnt stay at idle...
    for a few minute it was stay at idle. but the
    sound was not good.. and after it was sputtered
    and... died... and then i started engine.. but..
    it just died... again..again...
    so i equipted MAFT and then in base...
    i set base switch at C(it is leaner than stock)
    and then..my engine.. worked very well...
    it was stay at idle very welll and engine..sound.
    also.. good...and.. i didnt set wot switch...
    it set just at 0
    but matt said.. he didnt set idle rpm...
    he set just middle and high rpm...so..
    he said it should fine.. at idle...
    so i checked 1more time.. my engine...
    at that time. i found i got Air-Temperature Module
    from slp
    so i suspect that module..so i took off module..
    and.. also. mafte was took off..
    and then i started my engine.. but..
    it was .. same.. sputted...
    so i disapointed and then i equipted maft and
    then i set it again... but... set was differend
    with before i got Air-Temperature Module
    i set base switch at 0 and wot switch at o...
    the engine was good at idle...
    set 0,0 is.. notthing differnt with stock...right?
    but.. when i took off MAFT the engine.. idling
    was not stayable..at idle and sound was not good..
    why... is it happend.. to me.. im so sad...
    i got forged eternals.. with 8.5:1 and..welbro255
    fuel pump and 1.8rockersarm set and this time..
    my machanic broken my ngk tr'6 3 plugs..so..
    just he replace with stock with 0.035'gap~
    and full 3" exhaust...
    and i have slip to my p/d charger i set it 9psi
    but i could see 6psi and then rpm goes up~ but..
    boot was goes down..but.. it is not big problem..
    i can fix...so..
    when i drive my car... i couldnt....
    feel 250hp~ power...
    just.. 180hp~ car i feel drive...
    soon i will dyno.. my car and i will seeA/F ratio....
    do you know. why my car doing like this?
    any recommand.. will be needed...
    thanks..
    1997 firebird convertable.<br />intense 8.5:1 forged piston,rods,slp1.8 rockerarm<br />255welbro,28injectors,MAF,CIA headers,magnaflow exhaust,intercooled powerdyne S/C,TAXAS racing ECU tuning,coni shock with spring,roll bar,etc~
