Anyone else having this problem? From what my buddy told me, its because the intake pipe is all curved into the throttle body and messing up the air flow. The MAF reading is messing up the idle and making my car stall. Any solution for this?
FFF kit messing up the MAF reading
Nocutt, you'd have to put the entire TB infront of the turbo, as that's what the meter is calibrated for. You couldn't just move the element up there without recalibrating it.
The way you can fix the MAF issues with the FFF kit is to make the transition between the intake pipe and the TB alot smoother. This means rather than using an adapter fitting right there where they meet, make the entire pipe the same size as the TB opening, or before the pipe makes that last turn make the pipe bigger. It's very important that the pipe make the last turn with the same diameter as the TB. Also, leave the MAF screen in place.1998 Camaro, Arctic White<br /><br />Garrett P-Trim T04 turbo<br /><br /><i>348rwhp, 379.5rwtq @ 10psi</i>
is your screen over the maf? and did you reset the computer ?www.turbov6camaro.com
1997 3800 Series II Camaro
If you have a little money, you could have the stock maf post/sensor removed from the throttle body, the throttle body plugged and closed, use an SLP 85mm air meter and calibrate the computer, but thats some work.1997 Pontiac Firebird 3.9L<br /><br /> - TSP Dyno Tuned<br /> - Bored 0.040<br /> - ARP Rod Bolts / Head Studs<br /> - Custom CAI<br /> - Pacesetter Ceramic Headers / !Cat<br /> - 3\" Catback w/SLP Firehawk Muffler<br /> <a href=\"http://www.cardomain.com/memberpage/649312\" target=\"_blank\">http://www.cardomain.com/memberpage/649312</a>
Originally posted by viper04af:
is your screen over the maf? and did you reset the computer ?1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
The way you can fix the MAF issues with the FFF kit is to make the transition between the intake pipe and the TB alot smoother. This means rather than using an adapter fitting right there where they meet, make the entire pipe the same size as the TB opening, or before the pipe makes that last turn make the pipe bigger. It's very important that the pipe make the last turn with the same diameter as the TB. Also, leave the MAF screen in place.1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
umm un hook the tube and see if it runs.......www.turbov6camaro.com
Originally posted by ChronoGN:
That might be the part of the problem but I don't wanna put it back in.1998 Camaro, Arctic White<br /><br />Garrett P-Trim T04 turbo<br /><br /><i>348rwhp, 379.5rwtq @ 10psi</i>
We did one about 6 yrs ago with this setup, come to find out we could have gotten our MAF from www.splitsec.com
Anywayz we went to the boneyard pulled a MAF/TB from a w-body N/A and removed the TB blocked all the uneccessary passages, we cut the post holding the sample tube but left the screen intact. Car ran and idled like a champ...of course we have several aftermarket wayz to get the task done today...anywayz I am 101% sure this MAFs have a higher range than the "true MAFs"...like I have said int he past either our MAFs are configured for a blow-thru or put the darn thing infront of the turbo...
Just from my experience [img]graemlins/naughty.gif[/img]
Also on another note, I am thinking out loud here...what if the MAF tube (charge) is "venturied" into the MAF/tb itself? This will give time for the air to expand in the MAF (chamber) and allow for more readability? T-H what say you?
[ August 07, 2005, 01:31 PM: Message edited by: nocutt ]THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
Originally posted by nocutt:
Also on another note, I am thinking out loud here...what if the MAF tube (charge) is "venturied" into the MAF/tb itself? This will give time for the air to expand in the MAF (chamber) and allow for more readability? T-H what say you?1998 Camaro, Arctic White<br /><br />Garrett P-Trim T04 turbo<br /><br /><i>348rwhp, 379.5rwtq @ 10psi</i>
</font><blockquote>quote:</font><hr />Originally posted by nocutt:
Our MAF/TB uses the venturi effect already, behind the TB though...if you pick up our MAF and look underneath you will see it trying to taper...what I am proposing is...what if we created a venturi in front of the TB? eg rather than have a 3" straight pipe (charge) hit the MAF...we use say from the up-pipe (IC outlet) 2.5" and then about 6-8" away from the MAF/TB we start increasing the size...sorta like a cone till we get to 3" then into the MAF/tb. This way we can make the air expand better when it hits the MAF/TB...the side effect is more pressure drop though :( how much? it seems hard to say...Although you do get pressure drop anywayz, but I am not sure if this idea negates the whole thing? Maybe if we had a bigger MAF to start with say 3.5" which is actually what we really need in other to avoid running out of calibration...ok I am blabbering now ;)THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
T-H since we are forcing air...the TB is PLENTY enough IMO, the problem I see is guys running 85MM Mass Air Flows and having to shrink back down to ~76mm...lol!!
Our MAF/TB uses the venturi effect already, behind the TB though...if you pick up our MAF and look underneath you will see it trying to taper...what I am proposing is...what if we created a venturi in front of the TB? eg rather than have a 3" straight pipe (charge) hit the MAF...we use say from the up-pipe (IC outlet) 2.5" and then about 6-8" away from the MAF/TB we start increasing the size...sorta like a cone till we get to 3" then into the MAF/tb. This way we can make the air expand better when it hits the MAF/TB...the side effect is more pressure drop though :( how much? it seems hard to say...Although you do get pressure drop anywayz, but I am not sure if this idea negates the whole thing? Maybe if we had a bigger MAF to start with say 3.5" which is actually what we really need in other to avoid running out of calibration...ok I am blabbering now ;)1998 Camaro, Arctic White<br /><br />Garrett P-Trim T04 turbo<br /><br /><i>348rwhp, 379.5rwtq @ 10psi</i>
</font><blockquote>quote:</font><hr />Originally posted by ChronoGN:
That might be the part of the problem but I don't wanna put it back in.1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
So, putting it back in might fix the problem? I just heard that you should take those things out if you are running Forced Induction.1998 Camaro, Arctic White<br /><br />Garrett P-Trim T04 turbo<br /><br /><i>348rwhp, 379.5rwtq @ 10psi</i>
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...12 hours ago
