What should I do to the engine in preparation... - FirebirdV6.com/CamaroV6.com Message Board
  • What should I do to the engine in preparation...
    What should I do to my engine to prepare it for my turbo? What I actually mean is, what should I do to the engine to allow more boost after the turbo goes on? Until I get any engine work done, I dont plan on running any higher than 9 psi (water-air intercooled).
    Do you think I would have any problems running 9 psi on my 70,000 mile engine? Is there anything I should think about replacing?
    Im gathering parts now, and should be ready to do everything the first week after I get off of college- I have the turbo, intercooler, and wastegate, but I still need the fuel comp, injectors, and blow off valve.
    Thanks!
    [ December 31, 2002: Message edited by: Riles ]</p>
    All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
    umm, forged pistons and rods are a must. lower compression will help allow more boost 2 be run. heads/cam will allow it to breathe better and get more air in and out of each cylinder. ignition upgrades will help make sure all the air/fuel charge gets burned. ARP bolts will help hold everything together. upgraded gaskets will hold boost better and withstand time at higher boost.
      Actually your stock engine, assuming it is in good shape, can handle 9 psi intercooled, just fine.
      Just make sure you do a good job putting it in, monitor boost, etc.
      If you do have to rebuild, might as well build it for a turbo, however. Lower compression, new cam, turn up the boost.
      2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
        <blockquote>quote:</font><hr> Originally posted by strobhen:
        <hr></blockquote>
        What he said.
        The first mistake you can do when it comes to an engine with forced induction is run out and get forged parts. They can be pricey and not needed.
        With 9 psi, just make sure you have a scan tool so you can monitor your engine. Play around with it and find your engines weak points from that. Also, a MAFT+ would be nice.
        If you decide 9lbs is too much or you want to up the boost a little, lower compression pistons should be your answer. That will give you a lot more playing room. :D
        Thats about all I can think of for now.
        <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
          Thanks guys!
          Now that christmas break is over, I have to go back to another 5 months of gathering parts and doing nothing to my car :(
          Oh well, I guess the turbo will be worth the wait!
            advice:
            Before you go out & buy parts, find out what your getting yourself into. Talk to some people who have actually done it. Its not a walk in the park by any means.
            Do not expect it to be cheap either. I would plan on spending a good 3k for a good setup. Personally, I think I would rather go with Batman's ati kit myself. Lots of advantages -- like a self-contained supercharger (in respect to oil).
