Hey guys, trying to figure a few things out here. I'm building a shop car as kind of a rolling display of technology. Its a 1977 Volvo with a 1998 3.8 from a Firebird.
I'm going to use a stock Volvo intercooler and a TA49 turbo. Any input on what a SAFE amount of intercooled boost would be?? I was thinking about 8 - 9lbs initially.
Kelly \'GhoSSt\' Rosato<br />1996 Impala SS, 385ci LT4, 52mm TB, Quad1 headers, !Cats, !EGR, !AIR, Hooker Catback, SLP TC, UK3, UL0, GM CD changer, Onstar®, Homelink® Remote, lots of Fleetwood, Denali & 9C1 Stuff.<br />1998 Z28 Convertable (stock at the moment)<br />1993 Caprice 9C1, 406ci MPFI, overhead console, 8-way Riviera seats, DVD, CD Changer, etc..<br />1977 Volvo w/ 3.8l V6 from a 1998 Firebird
no more than 9-10 psi intercooled. if u look at the race-prepped blocks that intense racing produces u can run more boost. they come w/ forged rotating assemblies and a few other things, and ZZPerformance has stage 4 cylinder heads that will help out too.
<blockquote>quote:</font><hr>Originally posted by Arctc Wolf: no more than 9-10 psi intercooled..<hr></blockquote>
Good. I was aiming at starting at 10psi, so maybe I'll start at 8 and go up a little from there.
<blockquote>quote:</font><hr> if u look at the race-prepped blocks that intense racing produces u can run more boost. they come w/ forged rotating assemblies and a few other things, and ZZPerformance has stage 4 cylinder heads that will help out too.<hr></blockquote>
I might pick up a 3.8 just to make a monster out of. Studded heads and main caps, forged rods & pistons etc.. I asked over in advanced tech if anyone thought on Series II casting was a better donor for porting, but no one answered. How far back are 3.8 Series II heads interchangable?
[ January 06, 2003: Message edited by: Kelly Rosato ]</p>
The Series II heads from 3.8 from 96 on the L36 engine are interchangeable. You can also use the heads from an L67 engine which is just a beefier supercharged version or our L36 (found in the GTP Grand Prix). Basically any modern day OBD-II 3.8 from GM production lines is going to work.
The heads from the old school 3.8 turbo buick WILL NOT work. It's different motor.
<blockquote>quote:</font><hr>Originally posted by Pike: The Series II heads from 3.8 from 96 on the L36 engine are interchangeable. You can also use the heads from an L67 engine which is just a beefier supercharged version of our L36 (found in the GTP Grand Prix). Basically any modern day OBD-II 3.8 from GM production lines is going to work.
The heads from the old school 3.8 turbo buick WILL NOT work. It's different motor.<hr></blockquote>
Well, I kinda knew that the old engine/heads were a wash. My main question was if there were any castings that were 'more' desirable than others. I found several L67 cores from cars with engine fires and I may just buy one of those to rebuild. That way I get the long block with heads to port, and the lower compression forged pistons and forged rods. Heck maybe even a core Eaton thats worth a few buck to someone.
[ January 07, 2003: Message edited by: Kelly Rosato ]</p>
