Hey can I use the GTP fuel pressure regulator instead of an FMU for the powerdyne kit. Has anyone done this, and how would it work?
GTP FPR (MAGNUS)
GTP FPR (MAGNUS)
Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.Tags: None
A GTP regulator is regulated to 52psi at ambient pressure. It is a 1:1 so it adds to that 1lbs of fuel pressure for every pounds of boost. Work that way in the negative direction. I don't know how the powerdyne works, just thought I would give you specs on the GTP one.
DEE1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
What pound fuel injectors, does the GTP come with?Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
<blockquote>quote:</font><hr>Originally posted by phoenix64:
What pound fuel injectors, does the GTP come with?<hr></blockquote>
They say 36lb, but people that flowed them saw about 32-34lb. Yeah, we have ALOT of injector.
wow I had no idea.Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
GTP FPR is dif size than ours. It won't fit on our fuel rail.
I have pics on my website in the misc section.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
