Boost Gauge Install question - FirebirdV6.com/CamaroV6.com Message Board
  • Boost Gauge Install question
    I installed my boost gauge today and have the line running through the firewall but I don't know where to go from here. Could anybody show me a good vac line on the drivers side of the engine? Also I have been to every parts store around and nobody has the 1/8 Npt tee fitting I need to tap into the vac line so a part number or place to buy it would be a lot of help. Thanks in advance
    Garrett<br /><br />2001 WS9 W68 Blackbird A4<br />Custom Turbo...Chrome ZO6...WS9 Hood...<br />Custom Leather Interior...<br />much much more...see website<br /><br /> <a href=\"http://www.cardomain.com/memberpage/637795/\" target=\"_blank\">http://www.cardomain.com/memberpage/637795/</a>
    use the one on the fuel pressure regulator....
    look at home depot for the t fitting
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      I was there and lowes lol have any other suggestions?
        t off the line,,, get something from home depot with the little nipple
        so your boost guage is a 1/8 npt?
        you might have to use 2 apadpters for it to work
          the smallest they have is 1/4 " thats the prob. You think I should get two adapters to make it go 1/4"? Also what size is the vac line you recommeded?
            i know they make a 1/4 to 1/8th adapter then you can get the 1/4 nippler you need i ran into to same problem with my oil line for my turbo
              cool thanks for your help and is that vac line a 1/8" or 1/4" just so i know what to look for
                1/8 is good
                i personally like to use a small vac line and bigger nipple that way it will not blow off
                  auto part stores sell platic vac tee fittings i know they get down very small there.
                  12.8@110.21 04 srt4, stock computer, stock fuel, stock turbo
                    here you go.
                    http://home.comcast.net/~grayman99/V...onnections.htm
                    Also: you can flare the end of the copper tubing boost gauge line and slip the hose over the flare. I use small zip ties on all rubber/silicone hose connections as little hose clamps.
                    If you are using nylon tubing from the boost gauge thrue the firwall then check out by above link. I detail the types of npt fittings you need to transition from 1/8 to 1/4. It is ok to use 1/4 or 3/16 (suggested) for rubber/silicone hose connections becuase it just makes the connection tighter. use a little soapy water to lube the hose if need be...not oil or grease.
                    just in case....here is another link...it is for wireing into the fuse panel for gauges and stuff. I have more guides and info on my site for many FI related topics and mods.
                    http://home.comcast.net/~grayman99/fusepanel.htm
                    and
                    http://home.comcast.net/~grayman99/GaugeInstalls.htm
                    01 Firebird A4 3.42
                    Powerdyne @ 6 PSI
                    and other mods
                      thanks a lot man i appreciate all your help
                        ok I have it all set up with a 1/8" t connection on the end of the hose coming from the gauge...Now I need to put that t into the vac hose but I was wondering how I shoud do this. Can I just cut the vac hose above the elbow and put the two ends of the 1/8" t in there or is there another way?
                          i have not cut any of the stock vac tubes.
                          for manifold vacuum/boost reading i put a T on a stock vac elbow and then one small section of vac tubing to the manifold where I removed the elbow. the 3rd end of the T is connected to the boost gauge.
                          before the boost gauge though I have another T. one end of the T goes to a one way check valve and from there to the FMU. the other end of the T feeds the boost gauge.
                          You could cut a stock vac hose but I just don't want to do that. they are made of an unfamiliar (sorta hard) material and I don't know how well they stretch over barb ends.
                          01 Firebird A4 3.42
                          Powerdyne @ 6 PSI
                          and other mods
                            they don't at all, don't even try.. you have to have rubber hose to connect them.... :mad:
