The only thing to consider is that our cars go into boost at around 3 grand and every time you go to gas it, you might be doing holeshots...lol. Ask Andre about that. A while back I "had" a 2800 stall and it was ok. 3000 also worked fine. But the 2 converters I tried were crap when it came to making power and seeing gains, so I ended up sticking with the stock converter.
You will want to match the stall rpm to the rpm that you hit max boost from the PD. You want to make max use of the powerband you can. Since you have an SC, for a more streetable car, you'll want less str and more efficiency. if it's track, more str and less efficiency. Andre will set you up with a converter to match what you are looking for out of your car.
7 hours ago
