[Part One]
Okay here we go, got the charger on and it makes good 7lb's of boost [img]smile.gif[/img] lowest i get is 5lb's. My problem is the dipstick comes up and then oil shoots out when im under boost.
[Part Two]
I cut my stock exhaust off to get rid of restrictions (stock CAT is still on). Everything behind the cat has been removed. The problem still happens, when the motor sees high boost the dipstick pops up and oil squirts out.
[Help Me]
Is the stock cat that restrictive? Would my stock tubular manifolds be the issue? Where do i go from here? The car runs strong under boost but the oil / dipstick issue is BAD... The car is driveable if i granny shift it and dont get near 0 on the boost gauge...
* I did not do the throttle body mod listed in Mcaanda's install guide, i didnt see how it would make a difference, do i need to do that mod?
All my mods are listed below in the sig, i have NO HEADERS and STOCK CAT the rest of the exhaust is gone(I.E. laying on my garage floor)
I need ideas bad, thanks!!!
[Part Two]
[Help Me]
