dont get a DIS-4.. that would be a huge waste of money when we now have tuning software that will do all of that and more.. and its not a PITA to install.. www.hptuners.com
Ignition Timing for 9 lbs??
Now, I keep reading on this site that an intercooler eliminates the need for ignition retard. 1DangerousV6, are you not using an intercooler? I didn't see a reference to one on your site, unless I'm missing it. Does an intercooler really eliminate the need to retard ignition, or does it just let you retard less (assuming boost in the 9-12 psi range and 93 octane gas).2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Actuality the problem is several fold...
I have never seen the spark table for an L36, therefore it is my best opinion that not all the knock sensors are calibrated within the same range!?!...more sensitive modules or less do exist!
Saying this KR could be false due to the heat and power been generated by FI? that is one way to look at it! However I am also inclined to believe that 10psi on a stock engine with 9.4:1 CR is a lot granted the PCM commands almost 26 degrees of timing @ WOT. So cutting back some spark event will be a good thing in the long run or just running some higher octane fuel would help...THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
it can make it so you dont need to retard depending on how well it cools the air. if you have cooler air you will have less knock. and yeah dangerous are you running one, if not i would suggest getting one for boost levels that high.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Allthegoodnamesaregone nailed it. GET HPTUNERS (hptuners.com)! You will be able to see your spark tables, adjust just about every aspect of your timing (and fuel tables).
In addition, you can raise your rev limiter, speed limiter, remove O2 sensors (after the cat), calibrate speedometer, monitor and clear codes, and about 100 other things.
The tech support is fantastic and once you add up all the things it can replace (ignition control modules, O2 sims, speedo calibration device, MAF fuel modules, etc.) it is worth every penny.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
you need this, you can prgram it to use full timing up to what ever boost, for examlpe 8 pounds then after 8 pounds it will pull timing 1* then say for 10pounds it will pull 2*
MSD-6562 MULTI-CHANNEL BOOST RETARD
$396.39www.turbov6camaro.com
1997 3800 Series II Camaro
2 DIS 4 is not what he needs
3 HP tuners doe not know how much bosst he is making BUT will let him get max power
4 get the boost timing retardwww.turbov6camaro.com
Originally posted by 1DangerousV6:
Wolf..thanks for the tip...i've been looking at a DIS-4 ...mostly for the nitrous...i don't know too much about them so i didn't know you could really use it that much for a supercharger too...sounds cool...i'll have to check that outwww.turbov6camaro.com
hey guys...no im not using an intercooler...but was considering one...the plumbing for my application doesnt seem too complicated...yeah doesnt that hptuners software ROCK? [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
hey im not going to need a new belt to run the smaller, 9lb. pulley am i? ...i probably just need to tighten the tensioner down further?<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
My pulley was 2.75"
I ran a 103" belt. A 103.5 would be perfect.
I had to take the tensioner pulley bolt out, to get the 103 belt on, then put the bolt back in.
I don't know the length of the original belt.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
cool...then i'll see how the original one fits and if it doesnt i'll go with a 103.5 ...thanks John!<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
