Any one that can help me please do give me a list on what size turbo? piping size? anything i would need to turbo my 3.4 liter V6 camaro please help me!!!! Thank you for ur help [img]graemlins/rock.gif[/img]
turbo design
so much info can be found by searching....everything u need to know has been dicussed.......search and u shall find.Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015
go look around www.forcefedfab.com and you will find some info on the 3.4. i think they list the turbo size there. and pipe size i would recomend 3" if you can. and always search here before posting, there is a plethora of information on this site you need only look.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
What are your goals and where do you want to make power in the PRM range, how much boost do you want to run or not sure how much, 1 turbo or 2 and where do you wan to go your fastest?
Ex.
400hp
2500-6000
not sure
interstate\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
IM Looking to go atleast 13's but 14's is ok with me please give me any ideas you all have my motor has stock internals but i have flowmaster Exhaust, K&N intake system Ported intake, And computer chip... I just got a posi rear with 3.42's suspension consists of Eibach Sport Line springs... Headers are my next thing and to get the stuff togeather for my turbo set up. Please give me a size TURBO THAT WILL WORK WITH MY MOTOR this is a street car and will be driven alot lot just looking for more power to beat my friends that have Mustangs!!!! "YUCK"!!!!!! PLEASE IF U ALL COULD GIVE ME A LIST OF EVERY THING I WOULD NEED TO MAKE THIS HAPPEN.......... Thanks For your HELP and TIME..... TURBO3.4CAMARO
Well if you want a mild street turbo get a T04/T03 with a .80A/R exhasut side and .70ish A/R compressor.
For the trim on the compressor you will have to search because garret uses a letter system to rate there trims and I don't know what they mean.
Look at my cardomain site in the sig for my turbo 3.4 it will give you some ideas too.
You have to give you turbo oil and drain it to.
YOu will need a waste gate too, they vent exhaust from the turbine side so you don't boost your engine to pices.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
that would be a great turbo for you. you will also need to get an intercooler, a blow off valve, an FMU, piping, and i would recomend a walbro 255 fuel pump to be sure you get enough fuel.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
