Diagnosis: Murder - FirebirdV6.com/CamaroV6.com Message Board
Diagnosis: Murder
  • #16
    err GTP short block from intens is like 4000, i got all the plus heasds and cam for
    cam, push rods,springs 130#, TI retainers, pistons, connecing rods, install kit......$1950
    FFF heads..... $800
    Motor work $1775
    is like 4465 give or take for a fully biult ready for 20 psi motor
    oh plus 220 for the head gaskets...... lol
    www.turbov6camaro.com
    1997 3800 Series II Camaro
    • #17
      holy crap! ....thats a lot of $$$....but hey...if it can handle 20 psi ...that would rock!
      • #18
        http://viper03af.50megs.com
        • #19
          damn dude...thats NIIICE...any times yet??
          • #20
            I've got a set of L67 pistons and rods and also have a set of ARP rod bolts for the L67 rods. LMK if interested.
            • #21
              ok get an l67 short block, use your top end and accessories from your engine and you should be set. while your at it though port and polish your heads and anything else you want cause it will be cheaper to do when its out of your car and you are getting work done already. but the l67 will deffinately handle the 9lbs of boost and nitrous much better than our l36's will.
              • #22
                ahhhh...im kinda confused (not that hard) ...L67...is that the block from the GTP?
                • #23
                  yea l67 is the GTP block
                  http://www.bowtiev6.com/
