The turbo is too big..xhaust side. If you had an A4 without having to powerbrake you will not "see" full boost till about 4300-4500 RPM. On an engine that redlines at 5800-6000RPM there is no streetability...anything over .6 A/R (hotside) will be considered too laggy for the street...now on the other hand if you are trying to build something with 8alls then you will have to make a lot of changes from the stock configuration (regarding the engine)...it seems the turbo is good for 45lb/min of air flow which equates to about 450-500hp!!
THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
