Question for Taigo - FirebirdV6.com/CamaroV6.com Message Board
Question for Taigo
  • Question for Taigo
    Have you had your car with the turbo on, during the summer time? Im curious as to how it will run in 90+ degree weather. That would be my only concern with this kit as of now, because im not sure anyone has had it with this kinda extreme weather.
    im talking about the 3.8 kit
    This revelation, is the death of ignorance...<br /><a href=\"http://www.quicktimeperformance.com\" target=\"_blank\">www.quicktimeperformance.com</a>
    how bad is the turbo Lag (if any on your kit)
    any idea on the release date, ive saved up my pennies and i should have enough [img]smile.gif[/img]
    Green 97 Camaro RS 30th Ann.<br />3800 II<p><b>MODS</b><br />BORLA rear exhaust section, RKSport Headers, Hi-Flow Catylitic Converter, SLP CAI, Sylvania Silver Star Headlights, Eibach Pro Springs, Bilstein Shocks/Struts, 1LE Front/Rear 32/21mm Sway Bars w/Poly Bushings and Poly endlinks<p>And a bad @SS MTX System
      Well it got up to 100 degrees a few weeks and and it ran fine. Lately it has been up in 90s and all is well. It even likes 14psi in this heat :D
      2000 turbo/intercooled M5 Black Firebird<br />349.5hp and 415.3tq @ 4400rpms
        the ehat index here in houston has been around 109* for the past week or so and tiagos car is runnin fine. we were cruising down the freeway tonight with cp and a 35th anny camaro goin 110-115 the entire way. ran just fine.
          wword to the above :D
            Yup, even though I had to wait for you ladies to catch up....
            Cp
              Outstanding!
                <blockquote>quote:</font><hr>Originally posted by hou-tex-six:
                Cp
                <hr></blockquote>
                thats cause someone was trying to play cheech and chong, so i held back to make sure it was cool. then we went flyin by you.
                  Does your system lag BAD&gt;?
                    <blockquote>quote:</font><hr>Originally posted by foshizl:
                    Does your system lag BAD&gt;?<hr></blockquote>
                    <blockquote>quote:</font><hr>Originally posted by Tiago:
                    mine starts spooling at about 2500, full boost by 3500 rpms.<hr></blockquote>
                      if I hit hte gas, at a rpm where it can spool already, there is virtually NO LAG. Like yesterday on the hwy, just cruising at about 3500 rpm, its well into boostable rpm, if I put any load into the engine, instant 10 psi.... :D
                      cruising at about 80 mph at about 2500 rpm I can still get 5-6 psi pretty easily just putting load on the engine, about 2000 rpm I can get about 3 psi, etc.
                      [ June 26, 2003: Message edited by: Tiago ]</p>
                        those were the responses I was hoping to get!! cant wait to get this kit on my car :D
                          Man your kit is the shiznit cant wait till it comes out (ne ideas)? if you wanted to "expand" how do you go about making a turbo produce more then X pounds of boost? (what do you run in the 1/4)
                          [ June 26, 2003: Message edited by: foshizl ]</p>
                            <hr></blockquote>
                            All you need is a boost controler and you can set the boost to anything you want. You don't have to order a new belt or anything.
                              <blockquote>quote:</font><hr>Originally posted by Radcat:
                              <hr></blockquote>
                              the turbo supports upwards of 500 hp so its quite "expandable" all you need is a boost controller as said.
                              Im running mid 13s but hope to run better next week.
