Pics of Vortech Install - FirebirdV6.com/CamaroV6.com Message Board
  • Pics of Vortech Install
    This is the collection of parts to my Vortech setup. It includes a forward-rotating V1, race bypass valve, boost gage, FMU, and brackets. The toughest part was making it all fit with clever bracket fabrication. I used .250" 6061-T651 for the main bracket and the idler bracket and .750 round 6061 T651 for the bracket five stand offs. The belt is 115.25" and routes from the A/C compressor to the six-ribbed idler pulley on top(got rid of the original) which is supported by the bracket on the back of the charger, loops around about 300 deg. of charger pulley, then to the alternator. Use of original tensioner is preserved. Since it is driven by the back side of the belt, I media blasted the surface of the pulley and coated it with a very tough polysulfide compound to prevent slippage. It kind of feels like the grippy Fram filters.
    The hard work is done. All I need to do is plumb the intercooler, bypass valve and air filter. I originally installed one of those low-mounted intercoolers, but found out that those concrete parking space stop blocks are not very forgving. I've sence decided to mount a Saab intercooler behind the fan in front of the left side of the engine where I have room. It's small, but should do the job and even opens up the idea of using two of the same, one mounted in each fender using the fog lamp holes as air scoops. But that idea is for another day.
    Copy and paste link for the pics. Sorry for the quality of them. Next time I will use a better camera when I do the final installation.
    http://www.picturetrail.com/gallery/...31&uid=1273319
    180 Thermo, K&N Filter, Transgo stage 2, Pacesetters, Magnaflow cat, Flowmaster Catback, 3.42 LSD, Hotchkis LCA/Panhard, Bilstein, Eibach Pro, 1LE bars, SP crossdrilled/slotted rotors.<br /><br />Vortech Project 1.0 failed.<br />Vortech Project 2.0 in the works
    [img]graemlins/thumbsup.gif[/img]
      :D [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img] [img]graemlins/burnout.gif[/img]
        I give you alot of credit for that system. Can you give us more detail as to how we PD users can do this to our pulley?
        Have you tried it yet? Did the belt slip?
        My dad who's from Texas will be bring me some of the anti-slip tape. But if your idea is better, I would rather do that.
        Thanks
          I would like to help the powerdyne users out with my idea but it has not been proved effective yet. My system has not run. The pics were just a temp install for testing the belt length. While I was there I took some pics. As soon as it does run, I will let you know if my idea helps keep the belt from slipping. I am really counting on the amount of belt contact around the pulley to keep the slip to a minimum. If this doesnt work, I may try some other compounds I have access to. Possibly epoxy paint and sand.
            btw, I like those picture set-ups. A lot better than Yahoo album pics..this is a fast and easy way to view all the pics, and enlarge the ones you want to see more of.
            [ July 13, 2003: Message edited by: Camaro_SLP ]</p>
            94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
              Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
                [img]graemlins/thumbsup.gif[/img] Looking good!
