Super Six head and Cam and .. - FirebirdV6.com/CamaroV6.com Message Board
  • Super Six head and Cam and ..
    and 6lb supercharger what is the expected horse power. and would it help the SC? Would the interenials need to done as well?
    [ March 12, 2002: Message edited by: mike24 ]</p>
    Silver 2000 Firebird A4<br />3.8 A4<br />14.746 @91.98 Feb /03/02<p>1990 Mitsu GSX 5Spd I just got it.<p>Otis for President 04 !!!!!!
    I think it would work great. The p&p heads and intake and 3 angle valve job will greatly improve the air flow. The heads are slightly milled and therefore raise the compression to 9.6:1, from the stock 9.4:1, but it should still be able to handle the 6psi of boost on stock internals. You wouldn't want to raise the boost w/out fortifying the internals. As far as the cam goes, Tom from SSM told me my cam would work great w/ forced induction, but if you tell him ahead of time that you will boost it, he'll come up w/ more "boost friendly" specs.
    Good luck,
    Royce
    GM 3800 PowerPak guinea pig<p>\"what cam, that\'s just a nasty mis-fire...\"
      with this combo where do u guys think the HP would be around?
        Heads, cam and super charger......I would say 3-320 H.P. But I dunno.
        I have made a lot of money in my life, most of which I spent on cars and women.<p>The rest I have blown.
          maybe 13's in the 1/4????
            what mods you running currently? what rear gears you got? what are your tire specs? These things all can contribute to faster or slower 1/4 times and hp/tq to the ground.
            2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
