don't use wheel and tire combo's 2 compare to turbo wheels. u forget that 2 keep the same diameter, more tire has to be used on a 15" wheel than a 17" wheel, and makes up for the difference. neways, back to turbo's.
after the exhaust valve opens, it takes time for it to reach the turbo. the amount of time it takes depends on how close the turbo is to the heads. this is why ppl don't tent to put turbo's far away from the heads except in a few strange cases. yes, ppl have put them somewhat far away, but this is usually done to allow use of equal length primaries to also help spool the turbo faster and create less backpressure thru the turbo itself. something that also affects spool up, is the distance the air has to travel through the piping and into the motor. the shorter the path, the quicker boost will be achieved. granted, this might only account for 100-300 rpm, and not much of a worry on a street car, but on the dragstrip, it could mean a loss by a bumper, or a win by a bumper.
There is usch a thing as too small a wheel though. Larger wheels have better aerodynamic qualities because the material can be more precisely shaped than on smaller wheels. this is why civic's and integra's can't run twin turbo setups. because out motor has enough displacement, we would be able to run a twin-turbo system on our cars that would be efficient, but as I said b4, costly due to the amount of fabrication involved, as well as the clearancing and spacing inside the engine bay itself.
