Will the Eaton 3.8 supercharger off of a Bonneville fit in the Camaro? If so, what must be done?
3.8 supercharger
eeew man.. touchy subject around here with some.. but not me.. [img]smile.gif[/img] anyway will it bolt right up?.. no.. can it be made to work.. for enough money yeah.. do yourself a favor man.. go to the search feature and put in eaton.. you will see why I say it's a touchy subject..
goodluck-Brad
2000 V-Star Custom 1100
:rock:
anything can be done with enough money thrown at it. It requires that you get new heads and modify the firewall to accept the new throttle body position. Just as a suggestion, wait until we get the new ati kit out and put that one on.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
