My friend installed new SVO injectors in his 98 Z28 and has his stock 28.6lbs/hr injectors for sale. I know they will fit in fine but with a supercharged setup would they be a good idea or should I stick with my stock injectors? I will have a Maft+ pretty soon but any suggestions on this?
[ March 19, 2002: Message edited by: 97Pcam6 ]</p>
There is a formula to calculating how much hp you can squeeze from your injectors. I suggest doing a search on google and seeing if those injectors will be big enough for the amount of hp you will be wanting to run. Another trick will be leaning out the mixture with the maft, or upping the fuel pressure with an adj. fpr. have fun!
Not sure if this has anything to do with nitrous but when 12secV6 put in bigger injectors and didnt reprogram the PCM he blew his motor
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
