what do u do about your exhaust pipes? who leaves thiers they way they are and who coats them or somthing? Would it be fine to leave the pipes the way they are uncoated?
[ July 30, 2003: Message edited by: Shane ]</p>
Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
a) keeps temperature outside pipe down
b) keeps temp inside pipe UP, which is good for turbos, because it also increases the velocity.. the turbos feed off heat.
c) it looks nicer.
and... i don't have mine done [img]smile.gif[/img] but i do plan to soon.
