im still aiming to build some type of turbo setup in the future and i am now thinking of using a scavenge pump for one way i am thinking of. my question is how much do they cost (i know they arent cheap) and how hard would it be to hook up. also on eof my friends said i might want to add an oil cooler when i do this, whould that really be worth it because i dont see the need.
scavenge pump
scavenge pump
2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhardTags: None
where can i buy one from2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
yeah, you rule. thanks man.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
ok so is a scavenge pump the same as a bildge pump. they seem like they are.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
the tilton pump used on the incon kits, is a RV water pump, so your somewhat correct. not a bilge pump though, not fast enough, bilge pumps start at 360 GPH and go to 1000+
here is a good thread to read.
http://www.ls1tech.com/forums/showth...light=scavenge
Ryan1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
OK i found something on the weldon 9200 being used as a scavange, and it seems like my best bet. so all i need is like 1gpm for a t3/34 hybrid, right.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
