Temporarily NA... - FirebirdV6.com/CamaroV6.com Message Board
Temporarily NA...
  • Temporarily NA...
    After 1 year and 8 months of reasonably trouble-free operation (i.e. the car hadn't been in the shop overnight since August of 2000) the Virus' old reputation appears to be returning. With 80,000 miles now on the car, 50,000 of which are on the built engine, my supercharger has self-destructed.
    The charger sprang an oil leak somewhere during my 2020 mile round-trip to Chicago last weekend but I didn't think much of it and simply added another quart of Mobil 1 to fill up upon my return. I also noticed that I was pumping black smoke out of the tailpipes anytime I hit WOT but rather than fix it I just avoided using a lead foot hoping I could stall long enough to get it fixed after AIS. By the time I was leaving for AIS it had been about 2500 miles since my last oil change and all systems looked normal except a small bit of oil around the charger.
    At the shootout several people commented about the oil around it and my response was something along the lines of "I need to check that out when I get back..." (famous last words...). On the return voyage we were playing with a Mustang on the road in which I downshifted to 2nd on the highway and wondered why I wasn't taking off as fast as I should be. Glancing up at the boost gauge I noticed I was registering 0 psi at any rpm. Vacuum worked fine but at WOT the needle would not go into the positive. (Infernal, this might have been why I pulled away so slowly when you were videotaping me on the interstate--I was going to say, I should have had you by more than that margin.)
    As I was leaving AIS I heard a rattling sound coming from under the hood that was proportional to engine rpm. It sounded like the Almost-A-Cat was loose and rattling or something. The rattle got worse the further we went and finally in Richmond it was so bad I pulled over to check exactly what it was.
    Sure enough, the rattle wasn't the cat, it was the charger. The supercharger itself was making a horrible grinding noise, the gut-wrenching sound of metal grinding on metal. I limped home the remainder of the voyage and with VLKamikaze and MissY2KFirebird's help disengaged the supercharger last night. We cut the belt (glad I have a 2-belt system!) and disconnected the intake hose so now it's completely bypassed.
    www.firebirdv6.com/projectvirus/photos/disconnected01.jpg
    www.firebirdv6.com/projectvirus/photos/disconnected02.jpg
    The question that remained was, would the engine run NA? With the dropped compression and worked heads and cam, I had a horrible feeling that the engine wouldn't even start, let alone produce enough power to propel the car down the road. With my fingers crossed I turned the ignition--and the Virus roared to life with that Earth-shaking growl that so many people have come to expect from her over the years.
    But she sounded different.
    The trademark of my car, the memory every racer unfortunate enough to ever line up against me keeps forever--the telltale whine of the Procharger--was gone.
    But she ran.
    As of now I have pantyhose covering the throttle body and I'm looking to rig a dryer hose CAI attached to a K&N cone filter for the time being. I have to take the supercharger off, ship it to ATI in Kansas, pay possibly $600 for them to fix whatever inside it blew, and then put it back on. (Steve, Ryan, Mike93Z, and Roman, you guys remember what fun that was...) So as it stands I'm going to be NA for at least a month, and that puts my plans of the Centerforce clutch on hold again.
    So the Virus lives on but her venom has been temporarily removed. I'm driving very gently and all systems seem to be in the clear otherwise. Given the **** I've put her through, I do have to give credit to GM for building these things tough.
    Too stubborn to quit, too stupid to die. That's my baby girl.
    And the drama continues...
    [ April 22, 2002: Message edited by: Stefan ]</p>
    ahhh good luck my friend
    AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
      well said [img]smile.gif[/img]
      i wish i coulda heard it, you pulled past me but you were almost idleing, and since i was near the spinoutbox, i couldnt hear you at all :(
      03 Subaru WRB WRX<br />Clear parking lights<br />Autometer Phantom Boost guage
        did you change your engine oil after you disconnected the supercharger? if it was metal/metal grinding, there might be metal deposit that could tear up the engine...unless you have the self contained unit.
        oh btw, i made a mistake about mine it's a P600 [img]smile.gif[/img] my bad.
        2004 SRT4<br />2006 Mercedes ML350<br />1988 IROC - Supercharged and stuff
          Now with no blower it is time for my 3.4L to finally out run the VIRUS. LMAO :D Just messin with ya. How does it run with no blower? is it drastically slow with the lowered compression? At least it took a while for it to break again.
          <br />RIP<br />1995 Chevrolet Camaro<br />3.4L V6 A4<br />Flowmaster 40 Series<br />K&N FIPK<br />Throttle Body Coolant Bypass<br />180 Degree Thermostat<br />3.42 Ring Gear<br />Steel One Piece Driveshaft<br />IAT Relocation<br />and a website <a href=\"http://www.geocities.com/jason_b298\" target=\"_blank\">http://www.geocities.com/jason_b298</a><br />New Ride 2000 S-10<br />4.3L V6 VIN W<br />auto <br />3.42 w/ LSD<br />more coming soon
            sorry to hear that man... i've been using your car as a goal to aim for since i found this site. good luck.
            The Surgeon General never said anything about smokin\' a FORD
              So you are n/a for now???
              With a built motor???
              That engine is beggin for a bottle!!!!!!!!
              Awwww, come on, juice it now!!!!!!!!!!!!!!!!!!
                Ya know my idol DOES have a point....you "COULD" throw a bottle on that baby...and see how she likes its. I bet youd tear some roads UP with some N20 pumpin through the veins of that mean machine. Heck who knows...you "MIGHT" even like it better...but i think thats a long shot. id do it just until the blower is back. :D
                2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
                  Hahah james thats kinda f-ed up ..... well now that i think about not as bad as chanting NITROUS .... NITROUS while sleeping beauty was asleep HAHA [img]graemlins/rofl.gif[/img] oh what memories. Well at least she runs stefan. Good luck w/ the rebuild.
                  AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
                    I now see why everyone was picking on stefan about the cleanlieness of his ride..
                    -Brad
                    2000 V-Star Custom 1100
                    :rock:
                      I was really looking forward in seeing the Virus run. But hey, I know she'll be in top form again in no time.
                        I'm with James, I think you should throw on the bottle. It's a completely different feeling from the blower. I think you will like a nice healthy 100-150 shot. Boost is a fun thing in the upper rpm's but it just doesn't compare to that hit of a 100 shot at 3K. I can't wait to run some nitrous on top of boost. [img]smile.gif[/img]
                        Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
                          I'm sorry to hear about virus' troubles.
                          <blockquote>quote:</font><hr>Originally posted by Ironman24:
                          I'm with James, I think you should throw on the bottle. It's a completely different feeling from the blower. I think you will like a nice healthy 100-150 shot. Boost is a fun thing in the upper rpm's but it just doesn't compare to that hit of a 100 shot at 3K. I can't wait to run some nitrous on top of boost. [img]smile.gif[/img] <hr></blockquote>
                          What do you know about blowers and boost Michael? ;) I heard some people talking about your car at the last show. Calling you some crazy guy with N20 and a turbo. I saw it for my own two eyes. There was something big shiney thing on the front of the engine, but it wasn't a turbo. :D
                          Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
                          "I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre
                          http://seppo.hopto.org/
                            :D :D :D :D :D :D :D :D
                            1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
                              <blockquote>quote:</font><hr>Originally posted by Seppo Kaitainen:
                              There was something big shiney thing on the front of the engine, but it wasn't a turbo. :D <hr></blockquote>
                              I have no idea what you are talking about. [img]smile.gif[/img]
                              http://www.carolinafbodyclub.com/iro...mp/blower2.jpg
