Adjusting boost - FirebirdV6.com/CamaroV6.com Message Board
Adjusting boost
  • Adjusting boost
    I'm completely retarded when it comes to the details of a turbo set-up. I puchased a turbo that was recently rebuilt and a used BOV and wastegate. How do I adjust the boost so the first time I fire the car up it's not blowing any higher than the 6lbs that I want. My luck, it'll be set for around a full bar and then welcoming my worst nightmare of detonating the heck out of my engine. I'm guessing that starting from the bottom adjustment and working my way up is the way to go, but how do I do that. I bought an HKS sequential BOV...if that helps in telling me how stupid I am. Thanks
    Nitrous is like a hot chick with an STD....you wanna hit it, but you\'re affraid of the consequences...<br /><br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=244935\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=244935</a>
    if its internal wastegate it depends on the spring rate of it....just hook a vacuum line from the wastegate can to a nipple on the turbo for wastegate pressure....then later add a boost controler in that same vacuum line to make the boost higher
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
      Right. You can boost as low as the stock gate goes, likely 6 psi or so. If you're really afraid, just unhook the pressure-side tubing.
      Later, you can build a manual boost controller for about $10 in parts, or order one for about $50 to $100.
      -Rob
        Generally...however if you have a small turbo it can overspin...regardless of if it has a 'head' infront...moral becareful!
        THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
          What is your gauge reading? My BOV is kicking
          in pretty hard at only 3psi. The turbo is spooling rather well. Are you still having problems with building boost? Also the integral
          wastegate actuator can be calibrated by unscrewing
          the bar and tightening the locknut so that when you reinstall it the wastegate is partially open.
          This limits boost.
            This limits boost.
            I don't actually have it installed just yet. I'm going to start the install this weekend, but I'm going to be on and off due to my military responsibility. I'm going to be here and there for the next 3 months...so, one part installed here, one part a week later. I'm just trying to get all my ducks in a row before I start.
            Thanks for all the advice.
              Hope it works good for you. I found to vacuum leak and now the car is hitting boost like crazy
              at 2000 rpm. I still have to get the tuning complete before I go to all out full throttle.
              Please keep me posted on your progress. I have
              some more ideas in mind about the remote style
              that are feasible.
