I NEED TO KNOW WHAT ALL I NEED AND WHERE I CAN GET IT FOR A TURBO SET UP ON MY FIREBIRD. I NEED TO KNOW EVERYTHING ABOUT IT AND HOW LONG IT WILL TAKE ME IF I FABRCATE IT. I WILL BE BUYING ALL OF THIS IN ABOUT A WEEK. ALSO MY FREIND HAS A 1991 EAGLE TALON TSI THAT IS WRRECKED HE WANTS TO KNOW IF THE TURBO ON IT WOULD WORK ON HIS 1998 CAMARO.
TURBO HELP
much better, never use all caps again, its considered yelling.Now first off read the sticky i wrote at the top of the site (its full of good info for beginners). you can skip the sc stuff and skip straight to the turbo's. also just so you know this is not something you can just jump into and start building. You need to take your time and read about what others have done with our cars. please dont think you will be able to buy all the parts and put this together in a week. i have been researching turbos for almost 2 years and i am just now starting to build my turbo system. good luck, if you still decide to do this (i think a powerdyne sc would be a better beginner option for forced induction though).
Oh and please go to your duplicate thread and click on edit and then click in the box "delete post". thank you.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
A talon turbo.
Isn't that like a 16g or some thing?
If it is, then it is to small.
Stuff you need to make a turbo kit.
You need to have your car with you.
That is the most important one.
It helps if you can pull the exhaust manifolds off there and set the turbo(s) in there so you can make pipes.
The turbo you want to use, sized right.
It is good to have an intercooler.
Some where you will have to find the exhaust and intake air piping.
A plasma cutter, welder and knowing how to use them is a big plus.
When you have all those you are ready to start.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
