could you turbo charge and spray a 3.4? The engine will be rebuilt with forged pistons, new valve components, aarp head studs, and the best of everything else. I want to have it at 6-9 psi without an intercooler and 75 to 100 shot nos. What specs do I want for a custom cam grind to run both? What problems am I going to face? I'm determined to make this happen, if you can supercharge and spray why couldn't you turbo and spray.
NOS and Turbo 3.4
yea its possible [img]graemlins/rock.gif[/img] you just gotta figure out how to do it is all.
i dunno what all reasearch youve done yet on the subject but that one isnt gonna be an easy task
i dont kno much but for what you want id suggest Fast or dfi fuel management system, definately forged low compression internals, an engine girdle, and another 3.4l just in caseI pledge aliegence to the flag that sits on the front facia of my camaro and to the Mickey Thompsons that make it stand two tires under torque indivisable
dude you need to intercool with that type of a system or you will deffinately run hot and risk detination, and detination is not your friend!2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
talked to someone at garret and the intercooler is not needed as long as I stay below 9psi, at 9psi the air going into the intake is only at 190 degrees which is well within the range to run without an intercooler and I am prolly going to keep it at 6psi as long as I get the NOS to work right, I going to lose some power without it but it will make setting it up alot easier.<a href=\"http://www.cardomain.com/memberpage/594989\" target=\"_blank\">http://www.cardomain.com/memberpage/594989</a>
yeah man if your rebuilding make it so you can boost the hell out of that mother.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Originally posted by Tiago:
why the hell would you waste your time rebuilding and all to only run 8 psi? rebuidl it for at least 15-20 psi INTERCOOLED
then throw the 100 shot on top
do things right.<a href=\"http://www.cardomain.com/memberpage/594989\" target=\"_blank\">http://www.cardomain.com/memberpage/594989</a>
Tiago put down 340 to to wheels in his 3.4 and thats a stock bottom end , but for the life of me i can't remeber the PSI he was running but it was more then 9 PSI i do beleavewww.turbov6camaro.com
1997 3800 Series II Camaro
I am going to p&p the upper and lower intake, p&p-3 angle valve job-and comp cams valvetrain package on the heads, Ross forged pistons, Ross wrist pins, ARP rod bolts, ARP high performance head studs, mellings high flow oil pump, shot peen the rods, SPEC stage 3 clutch, LT1 throttle body, and the best gaskets I can get. I want a cam but don't know to what specs I should have ground and I can't find an engine girdle for the 3.4. Anything I'm forgetting?<a href=\"http://www.cardomain.com/memberpage/594989\" target=\"_blank\">http://www.cardomain.com/memberpage/594989</a>
umm high boost Tiago will tell you to go with the stage 4 clutch, Tiago (FFF) can also help you out with a custom cam grind, the heads p/p and your manafolds , umm the LT1 TB will not be easy but can be done. talk to him or Matt and they will "spend your money for you" in a vary good way.www.turbov6camaro.com
Where the h3ll do you get that stage 3 or 4 clutch or any thing like it from?
Some one please tell me.
I though I was going to have to put a 9.25'' S-10 clutck and hope for it to hold.
Turbo, sparied and 3.4 now your talking.
I you don't want to spend the mony on a inter cooler get a used on efrom ebay.
http://www.cardomain.com/id/oil_pan_4\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
I want to have it at 6-9 psi without an intercooler ...2001 camaro v6 red convertable<br /> ggotta go fast... I GGOTTTA GO FFAST! CCANT HEELP MMMYYSSELLLF<br />pics:<br /><a href=\"http://www.cardomain.com/id/darkthoughts5000\" target=\"_blank\">http://www.cardomain.com/id/darkthoughts5000</a>
Originally posted by viper04af:
umm high boost Tiago will tell you to go with the stage 4 clutch, Tiago (FFF) can also help you out with a custom cam grind, the heads p/p and your manafolds , umm the LT1 TB will not be easy but can be done. talk to him or Matt and they will "spend your money for you" in a vary good way.<a href=\"http://www.cardomain.com/memberpage/594989\" target=\"_blank\">http://www.cardomain.com/memberpage/594989</a>
