CFM rating - FirebirdV6.com/CamaroV6.com Message Board
CFM rating
  • CFM rating
    What is the average CFM rating for a garrett T3/T4 hybrid turbo? I just need to know if it is 400CFM or more.
    If you find any thing it will most likly be in lb/min.
      Sorry but you need to provide more specs and then search for the compressor map...t3/t4 means nothing but a family...
      anyhowz from the smallest trim to the largest available trim...I think you will be looking at ~28lb/min to about ~40lb/min (some even more when coupled with yet a bigger housing and hence bigger wheel...you will narrow it down with specs and their relative compressor maps..
      [ February 27, 2004, 10:32 AM: Message edited by: nocutt ]
      THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
        Is there any formula to convert lb/min to cfm. i know my question was broad, and im sorry, but i just cant find cfm ratings for any of them. thanks for the info though, ill try to find a conversion chart or something.
          there's alot of varibles you'd need for that. pressure and temperature are major factors try using PV=nRT. P = Pressure (atm) V = Volume (liters) n= number of moles (for air that can get complicated) R= gas constant (8.314?) T = temperature in celcius. This formula and some logic could give you an answer.
          2001 Pewder Firebird V6 A4 <br />Custom Turbo Kit Details On Site<br /> <a href=\"http://www.cardomain.com/id/njp98\" target=\"_blank\">http://www.cardomain.com/id/njp98</a> <br />Best 1/4 time NA - 15.224 seconds @ 87.55 MPH
            cool. thanks, i found some info on another site on how to come up with it as well.
