What is the average CFM rating for a garrett T3/T4 hybrid turbo? I just need to know if it is 400CFM or more.
CFM rating
CFM rating
2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhardTags: None
If you find any thing it will most likly be in lb/min.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
Sorry but you need to provide more specs and then search for the compressor map...t3/t4 means nothing but a family...
anyhowz from the smallest trim to the largest available trim...I think you will be looking at ~28lb/min to about ~40lb/min (some even more when coupled with yet a bigger housing and hence bigger wheel...you will narrow it down with specs and their relative compressor maps..
[ February 27, 2004, 10:32 AM: Message edited by: nocutt ]THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
Is there any formula to convert lb/min to cfm. i know my question was broad, and im sorry, but i just cant find cfm ratings for any of them. thanks for the info though, ill try to find a conversion chart or something.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
there's alot of varibles you'd need for that. pressure and temperature are major factors try using PV=nRT. P = Pressure (atm) V = Volume (liters) n= number of moles (for air that can get complicated) R= gas constant (8.314?) T = temperature in celcius. This formula and some logic could give you an answer.2001 Pewder Firebird V6 A4 <br />Custom Turbo Kit Details On Site<br /> <a href=\"http://www.cardomain.com/id/njp98\" target=\"_blank\">http://www.cardomain.com/id/njp98</a> <br />Best 1/4 time NA - 15.224 seconds @ 87.55 MPH
cool. thanks, i found some info on another site on how to come up with it as well.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
