Ok, I took the car back to the shop to find out why my boost was coming on a little later than usual. Had discovered a hole in one of the cheap
connectors I used on the intake tube. I replaced it with a gorilla thick rubber intake hump hose
reducer that will not burst. I tightened up every clamp in the intake system in the engine bay. I am going to get the car on a lift and get the ones underneath again. My question is if turbos will gain lag over a period of time. I am seeing full boost ok, and I hear the turbo spooling like crazy. I am just not getting the "off the line" acceleration like before unless I totally punch it. Maybe my tuning needs a little tweaking because I know that with a 10 to 1 ration FMU and 14% increase set on the MAF translator that it is overly rich. The timing is reduced to -8 degrees too. Any other suggestions
before I begin troubleshooting once again?
